93 Hatch LSx swap
Goto page 1, 2, 3 ... 34, 35, 36  Next
Otto347
PostPosted: Tue Jan 06, 2009 4:53 pm    Post subject: 93 Hatch LSx swap Reply with quote
Hello everyone! Just joined up on the board (found it through zilvia.net) and though I would post up the project!
Im still waiting on the title crap to get taken care of so I can bring the car home.
I picked up the motor 2 weeks ago:
GenIV LY5 4.8 iron block (with 480 miles on it)
LS2 intake injectors and timing set
224/226 .581cam
243 Casting heads with yellow beehives
Plans are:
Speartech harness
Custom Long tubes, engine mounts/tranny mount
T56 with spec clutch
Possible Tubular engine crossmember
17x9.5F 17x11R Some sorta wheels
and a few more things
One question is has anyone used the H3 oil pan for the swap? The engine still has the rear sump pan on it and I have a GTO pan ready to go but I saw the H3 and it looked like a better option.
Fueled wrote:
Funny shit, I hope no one was dumb enough to buy these pans and think they will work with the 240sx.
twistedsymphony
PostPosted: Tue Jan 06, 2009 5:01 pm    Post subject: Reply with quote
I don't think I've ever seen anyone use the H3 pan...
you got any pics of it? some pics next to a GTO pan would probably be best to determine how well it will fit.
Otto347
PostPosted: Tue Jan 06, 2009 5:34 pm    Post subject: Reply with quote
You know what, shame on me. I've been under the impression that the H3 was a front sump pan as well as the LH8 pan from BRP. I was wrong they are both rear sump. Sorry bout that Embarassed
§tev0n
PostPosted: Tue Jan 06, 2009 5:39 pm    Post subject: Reply with quote
looks good, seems like your somewhere around the same point in progress that i am with my 5.3
Otto347
PostPosted: Tue Jan 06, 2009 5:52 pm    Post subject: Reply with quote
Thanks, yeah ive been trying to get the car home so I can start on the mounts and such but the car was sold 2 times without a title transfer so I m having to go back and get ahold of the last buyer and get them to make me a bill of sale so I can bring it home!
§tev0n
PostPosted: Tue Jan 06, 2009 6:03 pm    Post subject: Reply with quote
lol that sucks.
are you making/modding your own mounts & crossmembers?
are those ls6 springs? what kind of cam is that? I'm still debating whether or not to put a cam in now or wait til later this year, I just don't feel like messing with the timing and all right now. But on the other hand switching out crank pulleys was so much trouble i don't know if i want to go thru it again.
twistedsymphony
don't even get me started about title issues...
It took me 6 months to iron out the title issues on my S14 from the time of deposit until the day I could bring it home.... NOT FUN times... Sad
yours at least seems straight forward... I had to deal with a shady dealer who sold it to the guy I was buying it from and he had all his paperwork locked up in some investigation into his business Mad
Best of luck...
Otto347
PostPosted: Tue Jan 06, 2009 6:49 pm    Post subject: Reply with quote
§tev0n wrote:
lol that sucks.
Yes and yes, the springs are the LS2/LS6 springs. As far as the cam goes all I know is the specs. 224 226 581lift 112lsa
What problems did you have with the crank pulley? I was just about to order one from summit but then again everything acc wise is going to be LS2 cause I dont have any acc as of yet.
Best of luck...
Yeah I still have the cash in my hand until everything clears.
Thanks!
§tev0n
PostPosted: Tue Jan 06, 2009 7:10 pm    Post subject: Reply with quote
the problem is a regular 3 jaw puller won't work, if you're careful you can get it most of the way off with a 3 jaw puller (without breaking it) then tap the pulley with a rubber hammer to get it the rest of the way off.
I broke two brand new pullers i rented from autozone during the process (good thing they have lifetime warranties so no $$ out of my pocket).
I just don't think $150 is worth it for the gm/snap on puller for our motors when you MIGHT use it once or twice...
ruth'lessdet
PostPosted: Tue Jan 06, 2009 8:25 pm    Post subject: Reply with quote
this is gonna be nice glws otto!!
LS2 Powered S14-Sold!!, Whats next?!?
trsilvias13
PostPosted: Tue Jan 06, 2009 9:29 pm    Post subject: Reply with quote
I got a no name puller and it works fine. One thing i discover is that when you mount the puller, it suppose to be inside the pulley. There are 3 tabs where the puller is suppose to be placed. It is not like pulling a traditionaly pulley where you would pull the OD pulley (lip area, near where the belts run). Not sure if I explained it right, but its a good tip if you never pulled a pulley off before.
Otto347
PostPosted: Tue Jan 06, 2009 11:45 pm    Post subject: Reply with quote
Thank you sir.
Thanks for that info, ill remember that!
§tev0n
PostPosted: Wed Jan 07, 2009 1:46 am    Post subject: Reply with quote
another problem is the stock crank bolt isn't long enough to use a puller.
there's a good write up on install university about it tho.
daftinnovations
PostPosted: Wed Jan 07, 2009 3:54 am    Post subject: Reply with quote
I remember when people use to talk crap about ls1 in a 240sx. I think its so funny. I think they were just big haters! Nice to see another project started. Weird seeing iron blocks. I just not use to it anymore Smile
90 s13 240sx coupe/90 toyota cressida
04 gto ls1/t56
1 3/4 long tubes
LS1 Swap Parts and kits for good prices
http://www.daftinnovations.com
View user's profile Send private message Visit poster's website AIM Address
Otto347
PostPosted: Sat Jan 24, 2009 7:28 pm    Post subject: Reply with quote
Got her home finally!
Someone else already got the motor out of my way!
its 80% gutted already too!
Only damage on the car....
All in all no rust and just minor things that a few trips to the u pull it yard will take care of!
Page 1 of 36
