Randall's S14
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
randall
PostPosted: Sat Jul 11, 2009 9:55 am    Post subject: Randall's S14 Reply with quote
I've posted a few pics but don't have a build thread so i thought i would share my build hammered tunnel cut and welded trans mount motor mounts trans mount since this pic i replaced the factory mount with a energy suspension mount power steering cooler mounts under front of oil pan heater hoses hiden under fuel rail covers factory temp sensor and steem vent tube mounts in upper rad. hose power steering ka pressure hose exhaust and 3.54 q diff receiver hitch replaces rear inner bumper made of 5'' channel q 45 frt brakes and 5 zigen gn+ 17x8.5 + 30
greddy2die
PostPosted: Sat Jul 11, 2009 10:46 am    Post subject: Reply with quote
Sweet, looking good.
Not used to seeing dual exhaust on 240's but I dont think it looks bad. The piping looks pretty darn good.
*thumbs up*
Oh the joy Smile
11.8@121 w/ 1.9 60' (open diff)
ASAPerformance built
randall
PostPosted: Sat Jul 11, 2009 10:51 am    Post subject: Reply with quote
I found a few more pics gto shifter, i had to shrink the base down about 1'' to fit under console trans cooler power steering after build trans mount with poly mount
randall
PostPosted: Sat Jul 11, 2009 10:52 am    Post subject: Reply with quote
THANKS
Gjohnson
PostPosted: Sat Jul 11, 2009 1:18 pm    Post subject: Reply with quote
Looks good man. I may try to use the stock Ka Pressure hose as well. If I remember right you had to trim some off of the bolt right?
Exhaust looks mean.
Kouki Project
NoClassic
PostPosted: Sat Jul 11, 2009 4:50 pm    Post subject: Reply with quote
Looking good man.
The brazed cooper pipe is a bit questionable, but as long as it dosnt leak I guess it works.
I would consider making a mount for the trans cooler and putting in front of the radiator. Those push through tabs will destroy the condenser over time. The cooler itself will also pick up alot of heat being sandwiched between two hear sources like that.
jmauld
PostPosted: Sat Jul 11, 2009 6:20 pm    Post subject: Reply with quote
Did you make this piece or find it?
randall
PostPosted: Sat Jul 11, 2009 9:20 pm    Post subject: Reply with quote
jmauld wrote
i have table top smithy lathe and mill i made that with and took it too a welding shop and had them welded on after this pic was taken. i made a mistake of not having a ground terminal welded too the body and the gauge did not read correctly. i currently have a hose clamp holding the ground to the sensor. someday when i have to drain the coolant i will have a terminal welded to the bottom side
randall
PostPosted: Sat Jul 11, 2009 9:53 pm    Post subject: Reply with quote
Exhaust looks mean.
no i did not do anything to the bolt. i just bought 2 new washers. the exhaust i mounted the mufflers and bought three mandrel j bends to use behind the rear end and the x pipe. i took the car to a friend that who does exhaust work at his house. he done a excellent job.
randall
PostPosted: Sun Jul 12, 2009 10:53 pm    Post subject: Reply with quote
NoClassic wrote:
Looking good man.
thanks ya i still have my concerns about the copper fittings myself. its the first time I've done anything with copper but so far its holding. for the trans cooler I've thought it might get hot when i get the air going but the cooler is twice the size recommended for that trans
randall
PostPosted: Sun Jul 19, 2009 1:39 am    Post subject: Reply with quote
i went to the drag strip for the first time ever to see how my car would do. the best time was a 8.152 with a 1.91 60 ft. in the 8th on street tires.
twistedsymphony
PostPosted: Fri Jul 24, 2009 9:53 am    Post subject: Reply with quote
what did you do to get the tunnel so smooth like that?
I'm jealous, I want to re-do mine now Laughing
greddy2die
PostPosted: Fri Jul 24, 2009 1:15 pm    Post subject: Reply with quote
haha yeah I noticed that too. the tunnel looks really good nice and smoothed out like that
randall
PostPosted: Fri Jul 24, 2009 11:02 pm    Post subject: Reply with quote
thanks, i took a 3 or 4 lb. sledge and rounded it like a broad ball pen so it didn't leave any sharp indention's. and it probably didn't hurt that the tunnel had to be stretched so tight to make room for the auto.
randall
PostPosted: Sat Jul 25, 2009 10:06 am    Post subject: Reply with quote
i was at cruise-in and got a look at a 2010 camaro, the heater hoses are a lot like i done mine. i don't know how it is under the covers or behind the head but it might could be used on the 240.
Page 1 of 9
