s13 Turbo 5.3 Blow threw carb build
Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
rb25drag
PostPosted: Fri Jun 18, 2010 11:23 pm    Post subject: s13 Turbo 5.3 Blow threw carb build Reply with quote
I been on the forum for a few months now asking questions. I finally started making some progress on my build. Thought I would share a few photo's.
Basic setup: Engine
2000 5.3 (Stock internals)
Stock coils
Gto oilpan
ls1 carb intake
Quick fuel Blow threw carb
MSD stand alone ignition
tci flex plate (th400)
Trans Dapt motor mounts
60mm Precision turbo
synapse wastegate
hks bov
Water intercooler with ice tank and pump
Transmission:
Powerglide with transbrake
3500stall
ratchet shifter
Shaftmasters Custom driveshaft
suspension:
Brembo drill/slotted rotors
ss brake lines
Hurst line lock
Rebuilt stock calipers
New struts with Tein lowering springs (rear modified more)
New axles (stock r200 welded rear end)
Wicked racing adjustable control arms
Weld Drag lites 15x4 Front 15x8 rear 5.5 backspacing
Nexen front runners
M/t 26x10.5 et streets rear
I got the fire wall painted
Had to move the radiator to clear the turbo. built a new support and made new headlight brackets and hood latch bracket.
Had to notch the frame so the lower radiator hose will fit in the new location.
Gto oil pan
Performer carb intake
specter carb hat
new fuel pump
new fpr
Turbo and turbo manifold mounted.
Motor mounts
Rob_br_91
PostPosted: Sun Jun 20, 2010 11:14 am    Post subject: Reply with quote
Damn nice rs13! I want to see it done. Smile
Ur rear spoiler looks like GT-R HCR32 OEM spoiler, perfect touch BTW, maybe because it seems a lot of that of the type-x rear spoiler.
Cheers!
S14 LS2 RHD, One Day...
View user's profile Send private message MSN Messenger
LS1S13
PostPosted: Sun Jun 20, 2010 4:17 pm    Post subject: Reply with quote
Do you have any exterior shots of the car with that hood from farther back?
rb25drag
PostPosted: Sun Jun 20, 2010 5:55 pm    Post subject: Reply with quote
here is a couple more shots of the body
LS13.5
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 21, 2010 1:33 am    Post subject: Reply with quote
haha it looks like a fuckin 3rd gen maro... i like 3rd gen maros btw haha
88gutlass
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 21, 2010 3:19 pm    Post subject: Reply with quote
shit is dope!!!
rb25drag
PostPosted: Mon Jun 21, 2010 8:17 pm    Post subject: Reply with quote
Well I have. a guy trying to screw me over on the th400 trans, I'm getting my money back, I think I'm going to purchase a powerglide with a trans brake and a 3500 stall. I believe it will make more power and with the turbo setup with gearing of the stock r200 rear end.
rb25drag
PostPosted: Thu Jun 24, 2010 8:22 am    Post subject: Reply with quote
Well I got the motor set down last night, I got my crossmember finally notched so I could set the motor back as far as possible for my turbo clearance. Im going to run into some major hood clearance issues, Looks like a 6" hood scoop is in the future. I just throwed a junky carb i had laying around on it and my turbo hat. Its 6" above my strut towers.
Im going to cut my motor mounts down another 1/4 inch
rb25drag
PostPosted: Sun Jun 27, 2010 7:02 pm    Post subject: Reply with quote
I got my oil pan return bung welded in. So the turbo is almost complete. Now I'm just waiting on the powerglide to arrive so I can finish it.
TurboGoKart
PostPosted: Sun Jun 27, 2010 9:10 pm    Post subject: Reply with quote
Sweet man!! Lookin good. Those wheel make the car look naaaasty!! Twisted Evil
If you want something done right, do it yourself.
rb25drag
PostPosted: Mon Jun 28, 2010 5:38 am    Post subject: Reply with quote
Ha ha thanks man. I do enjoy those wheels. The car always draws attention at the track. Most imports hate me tho lol!
eady76
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 28, 2010 11:02 am    Post subject: Reply with quote
dude, im sorry, but threw is the past tense of throw. the word you are looking for is "through" as in blow through carb. i usually try not to be a grammar Nazi but this is just plain wrong.
rb25drag
PostPosted: Mon Jun 28, 2010 12:15 pm    Post subject: Reply with quote
Ha ha ya well if you search online, some say threw, thru, and through, I've found more information by searching threw.
eady76
Lv2 Member
Lv2 Member
PostPosted: Wed Jun 30, 2010 3:31 am    Post subject: Reply with quote
threw is the past tense of throw. are you throwing stuff through your motor? i guess the air from the turbo could be considered "thrown". anyway, nice build. its great to see progress! its a hella impressive setup no matter what its called.
rb25drag
PostPosted: Sat Jul 03, 2010 9:18 am    Post subject: Reply with quote
Got my oil return line made for the turbo:
I just purchased the powerglide w/transbrake and a 3500stall
Page 1 of 8
