Hooker S13/S14 Mild & Stainless Steel LS Engine Swap Hea
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic   Reply to topic    silviav8forums.com Forum Index » Hooker/Holley EFI
s14blane
PostPosted: Fri May 18, 2012 11:54 am    Post subject: Reply with quote
Under car shot with stainless installed on my car from the other day.... Yes I know I need to clean off the trans a bit more.....
mobceo
PostPosted: Fri May 18, 2012 10:03 pm    Post subject: Reply with quote
s14blane wrote:
NoClassic wrote:
It looks like you are right about the cast manifolds. I talked to Scoggin Dickey in February and they still did not have the part number in their system.
We were going to use them in an S10 chassis that had an early chevy truck body.
It would be cool if you could test fit the cast manifolds with your S-Chassis mounts. If you have not already.
I had those same thoughts initially NoClassic. Unfortunately the steering rack on the S13/S14 would necessitate changes to the design of those manifolds.
well no done three s14's and one sc300 so my car has been on the back bunner
Nismo
PostPosted: Tue May 22, 2012 12:35 pm    Post subject: Reply with quote
Is there any interest in making all of this for the 350z and g35 platform? If you need to check look at my350z there are a number of people doing the swap now with more everyday added.
s14blane
PostPosted: Wed May 23, 2012 4:12 pm    Post subject: Reply with quote
Thanks for the heads up on the 35Z and G35 platforms "Nismo". One of our focuses is to see how our parts fare for this particular chassis and then we will definitely entertain the idea of producing swap parts for other platforms.
Thanks for posting!
turbociv910
PostPosted: Wed May 23, 2012 10:00 pm    Post subject: Reply with quote
do you think they will fit around a th350 trans with an ultra bell?
will they be available on summit, jegs etc?
brewster240
PostPosted: Thu May 24, 2012 8:23 am    Post subject: Reply with quote
You should answer pms.
s14blane
PostPosted: Thu May 24, 2012 9:56 am    Post subject: Reply with quote
To turbociv910:
These mounts were not designed to accommodate the use of any automatic transmission. The one we considered working with would have been the 4L60 but in the end we would have had to compromise the design of both the T-56 mount and headers.
The ground clearance would have taken a hit if you'll pardon the pun. Another one of our design focuses was to allow routing of fuel lines in an OEM fashion without heating them up to much, and we didn't want to have to sacrifice that design either.
To answer your other question, these will definitely be available through our normal distribution channels like Summit and Jegs as soon as they are available.
s14blane
PostPosted: Thu May 24, 2012 9:57 am    Post subject: Reply with quote
Brewster240, I just saw your message and replied to your message. Thanks a lot for getting in touch!
88gutlass
Lv2 Member
Lv2 Member
PostPosted: Thu May 31, 2012 6:54 am    Post subject: Reply with quote
This is great!! I'll definitely be ordering a pair for my build!!
brewster240
PostPosted: Thu May 31, 2012 8:42 am    Post subject: Reply with quote
I'll be ordering a few pairs if they get out on time.
s14blane
PostPosted: Fri Jun 01, 2012 10:49 am    Post subject: Reply with quote
Good to hear 88gutlass!
lol, Good to know, although I'm sensing hints of sarcasm, haha. I talked to one of our engineers just yesterday and he said everything is in it's final state of completion and should know pricing and solid release dates very shortly.
Brockstar
Lv2 Member
Lv2 Member
PostPosted: Fri Jun 01, 2012 6:05 pm    Post subject: Reply with quote
It would be awesome if you slotted the trans crossmember holes so that it will work with other mount kits. For instance, I'm mounted with a motor plate and a McKinney trans crossmember (that I acquired - I would never pay for their garbage) and it is terrible! I had to grind out the slotted holes to the point that I'm probably going to modify it or replace it entirely.
View user's profile Send private message Visit poster's website AIM Address
brewster240
PostPosted: Sat Jun 02, 2012 7:59 am    Post subject: Reply with quote
No sarcasm at all. I'm building 3 cars right now with 3 different kits, I'd rather have them all the same. I sent you info in a pm, and also called hooker, but I can't seem to get any valid info on a release date, and I'm on a schedule.
88gutlass
Lv2 Member
Lv2 Member
PostPosted: Sun Jun 03, 2012 6:58 pm    Post subject: Reply with quote
Yea none at all.. Just glad to see some affordable/quality headers on the market..
mobceo
PostPosted: Mon Jun 04, 2012 1:25 am    Post subject: Reply with quote
fingers tapping on desk
Post new topic   Reply to topic    silviav8forums.com Forum Index » Hooker/Holley EFI All times are GMT - 4 Hours
Page 2 of 10
